configure mpls rsvp-te timers lsp standard-retry
configure mpls rsvp-te timers lsp standard-retry {decay-rate percent} {delay-interval seconds} {retry-limit [number | unlimited]}
Description
Configures the timers associated with the establishment of an LSP.
Syntax Description
percent Specifies a percent increase in the interval allowed before each subsequent attempt to re-signal an LSP. The valid range is from 0 to 100 percent.
seconds Specifies the time (in seconds) to wait before attempting to re-signal the LSP.
retry-limit Specifies the maximum allowed attempts to establish an LSP.
number Specifies a maximum number of allowed attempts to establish an LSP. The valid number range is from zero to 255.
unlimited Allows unlimited attempts to establish an LSP.
Default
Delay interval: 30 seconds.
Decay rate: 0%.
Retry limit: unlimited.
Usage Guidelines
This command configures the timers associated with the establishment of an LSP. If an LSP fails to establish, the LSP is re-signaled based on the configuration of these timers. The delay-interval timer specifies the time (in seconds) to wait before attempting to re-signal the LSP. If the LSP fails to establish itself on subsequent attempts, the delay-interval time is incremented based on the decay-rate setting. The decay operation multiplies the delay-interval time by the decay rate, and adds the result to the current delay-interval time. For example, if the decay-rate is set to 50 percent and the current delay-interval time is 30 seconds, the LSP is re-signaled in 45 seconds. If the LSP failed to establish on the next attempt, the delay interval would be further decayed to 67 seconds.
A per-LSP delay-interval time is maintained for each LSP until the LSP is established. This operation of decaying the retry time continues until the LSP is established or the retry-limit expires. If the retry-limit is reached, attempts to establish the LSP are suspended.
Disabling and enabling the LSP resets the LSP's delay-interval time and retry-limit to the initial configuration settings and LSP establishment attempts resume. The default LSP timer parameter values are 30 seconds for delay-interval, with a 0 percent decay-rate, and retry-limit of unlimited. The valid range for delay-interval is 1 to 60 seconds. The valid decay-rate range is 0 to 100 percent. The valid retry-limit is 0 to 255 or unlimited. A value of 0 indicates that the LSP is not re-signaled.
The following command allows unlimited retries for establishing MPLS RSVP-TE LSPs:
configure mpls rsvp-te timers lsp standard-retry retry-limit unlimited
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
